Window Problem Please Help
Old Feb 2, 2007 | 06:18 PM
edz88irocz28's Avatar
Car: 1988 Iroc-Z28
Engine: TBI 305 Bored 30 over mild Mods
Axle/Gears: Stock
Ok it's been some time since this has happened. I installed a radio myself and I know alittle about it (basic i would say) I rolled down the windows due to the hot weather and after installing the radio i might have shorted something because afterwards the windos would not go up. So I pulled the panels off and ran power to the motors and they went up now I have checked the circuit breakers and replaced them how rare is it for both swicthes to go out at the same time i removed them and checked them anyway there is no corrosion i do not remember if i disconnected the batter i'm almost sure I did but any advise would be helpful on where and what to look for and also is there a relay for the power windows and where is it located? thank you for your time to read my post
Old Feb 2, 2007 | 10:32 PM
Vader's Avatar
There are no relays for the window motors. They are operated directly by the switches. There are thermal overload units in the motors themselves, but if the motors worked by directly supplying power to them, that is not a problem.
Check for voltage and ground at the switches, connections at the doors, and connections at the motors.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
