Harmonic balancer question
Old Feb 2, 2007 | 07:48 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Hey guys this might sound kind of funny but, are OE engines internally or externally balanced?
What effects occur when the wrong dampner's are used?
Old Feb 2, 2007 | 11:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All SBCs are internally balanced, except for the 400 which was externally balanced and uses a unique damper.
Someone is going to come along and say that the 1 piece RMS engines are externally balanced, followed by someone else who will say that they're not. Either way it makes no difference to the damper.
Old Feb 2, 2007 | 11:47 PM
AtomicTruck's Avatar
Car: Pro Stadium Tough Truck
Engine: Buick V6 272 cu in
Transmission: TH350
Axle/Gears: Broken most of the time
I helped a friend swap an old 327 out of a stub nose chevy van (late 60's) vin 010 into a truck that had a different balance scheme (74 or so chevy truck 350..). Memory is failing me at this point but IIRC the 327 was internal and the truck was external. Not sure on this exactly. This swap was done many many years ago.
The thing almost vibrated itself to death (fact from personal experience) . As the story goes, the freind changed the flex plate and that curred the problem. I didn't help with that part so I can't confirm the fix.
Old Feb 3, 2007 | 12:05 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The 327 and 350 are both internally balanced. If the truck had a 400 and you tried to reuse the flywheel you'd have that problem.
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
