What kind of power would you expect from this setup??
Old Feb 2, 2007 | 09:36 PM
redtail2624's Avatar
Car: 88 TA
Engine: 383 Converted LT1 intake
Transmission: TH350 3500 stall
Axle/Gears: 12 bolt 3.73's
Fuel Injected 383ci., LT1 Intake, Trickflow 195cc heads 62cc combustion chamber , Comp cams 230/236 cam, Hooker super comp headers, 9.5:1 compression, Fast chip mail in tune, 3 inch flowmaster exhaust. Also what could you expect to put on the ground with a setup like this running through a TH-350 Transmission with a 3500 stall and a 12 bolt with 3.73 gears??
Old Feb 2, 2007 | 10:06 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Maybe 340 to the rear wheels. But I see three problems. You are leaving 20 horsepower on the table with the 9.5:1 compression instead of going to at least 10.5:1. You also need to find our what your dynamic compression ratio is.
Fast Chip mail order tune. You need a custom tune for max power and drivability. Last the flowmaster muffler. They are good for sound only. Get a Magnaflow or Dynomax.
Fix those items and you should see well over 370RWHP if your exhaust is up to par.
How well is the LT1 intake going to match up to the Trickflow heads?
Old Feb 2, 2007 | 10:52 PM
Car: 88 TA
My dynamic compression will be low 8 point something.
Old Feb 2, 2007 | 11:18 PM
Car: 1989 GTA
Engine: 369 TPI
With a good quench you can up to 8.5:1 on the DCR and 91 octane.
Old Feb 8, 2007 | 10:43 AM
Car: 88 TA
Well I have decided to go with 10:5:1 compression and get it dyno tuned.
jhawkeye
May 25, 2022 06:33 PM
stalkier
Dec 6, 2015 11:25 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
