1987 Firebird Starter Problem
Old Feb 3, 2007 | 02:48 PM
Sphinxz28's Avatar
Well i just picked up this 1987 Firebird Formula 350 tpi for a good deal about a month ago. then the starter died the other day, i crawled under there and disconnected the starter but i noticed almost instantly the amazingly horrible placement of the exhaust.
I got the starter loose and now all i can do is jiggle it between the exhaust and the A-Arm. It looks almost impossible to get out unless i take the exhaust off. Has anyone ever done this before!? Any help would be great. Thanks.
-sphinx
Old Feb 3, 2007 | 03:03 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
Yes I had to do mine twice last year.I had to drop the exhaust both times.If your exhaust is in good shape it's not so bad.
Also, did you make sure that the starter is bad?Is the battery good?Check for signal going to soleniod from the key(should be around 10 to 12 volts while cranking).Check for 12 volts power to the starter.Check ground at starter housing.
Old Feb 3, 2007 | 08:59 PM
InsomniacZ28's Avatar
Car: 1984 Z28
Engine: 305ci V8
Is that with the key turned and the car cranking? Or just with the key at half turn? You seem to know what you're talking about. Please go look at the problem i'm having in my post...I believe its electrical.
https://www.thirdgen.org/forums/tech...se-please.html
See if you can help maybe, thanks.
Old Feb 4, 2007 | 12:53 PM
jocool's Avatar
Not the acc position.You need someone inside the car trying to start it while you check the line from the key to the soleniod.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
