tach needle goes to redline on startup ?!
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
im in the process (and almost finished) cleaning up my engine bay, moving wires and stuff around, painting in there, relocating things.. and i hooked up the battery to runt he car last week, and it ran good; jsut a little smokey cuz i didnt have the MAF sensor plugged in. when i revved the car the needle ont eh tach was NORMAL
today, im inthe garage again, and needed the battery hooked up to put up the windows in the car; and i hook up the battery; and MAF sensor too; and as soon as i turn the key to IGN, the tach needle maxxes out (goes to 7000 redline), i turn the car on, and the needle STAYS there, but the car idles normal (about 1200) and revves up just fine, but the needle is pinned at 7000 - maxxed out
any ideas?
fuse?
wire?
other problem ?
thanks
dave
any ideas?
fuse?
wire?
other problem ?
thanks
dave
Car: 87 Camaro IROC
sounds like bad wires, check the wires at your distributor and coil, mayb you jarred something or thers a wire with a bad connection.
Car: 1987 IROC-Z
thanks gramps; you were right
i must have bumped one of those wires and made the connection loose, so i went int here and loosened up the tangle of wires a bit,a nd now the needle is reading normally again, thanks dude
Car: 1987 IROC-Z
i was going to do that; i was just reading my 1987 SHOP manual, and discovered that it is the white wire; i will trace it tomorrow afternoon when i get home from work
thanks for the replies fellas,
i also think that is has something to do with my alarm setup (that the original owner had installed)
-its a "chelsea alarm" which is a button that when you push it in, it cuts off signal to the distributer, and locks down the hood(well used to, on the steel hood, now mines glass), because i also was fiddeling with the alarm wires during the past few days
ill trace the wiite wire tomorrow and check it on a volt meter
