dart pro 1's
Old Feb 5, 2007 | 02:46 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
dart pro 1's
im looking to get some new heads with my income tax i was looking at these dart pro 1's on ebay http://cgi.ebay.com/ebaymotors/Dart-...85390389QQrdZ1 i was going to get these or i see some dart platinum heads 200cc asembeld for the same price. would the pro '1 be better or should i get the platium heads there going on a 355 with mild cam. also i seen that the pro 1's have 72cc chambers what would be the compression with flat tops. i also have a set of brand new speed pro .275 domed pistons from a different build what would the compression be with them. thanks.
Old Feb 5, 2007 | 03:15 PM
That is not a good deal; and it's not the right heads for your application, if you have a N/A 350. Before you bite off on that, compare the price that it will tke to assemble them - valves, seals, springs, shims, studs, guide plates, & setup labor - and see if buying those blems off of somebody that bought a truckload of them and rescued them from the scrap heap, will cost any less than buying first-run assembled product. I think you'll find out that these here would not save you anything.
Dart iron 180cc heads, 64cc angle-plug, would be a better match for what it looks like youve got: a stock 350 TPI.
I don't think those pistons will fit in the Dart combustion chambers without some machine work. After all, they're made as stock replacement pistons, to go in stock heads. Besides, they will give you over 13½:1 CR with zero deck, and almost 12:1 with a stock deck height and lowered compression height. Basically they are worthless to you.
Old Feb 5, 2007 | 03:36 PM
Car: 1987 iroc z
the motor is a 355 street dominator intake holley 650 dp cam is a 510/488 lift 234/244 @.50 duration flatop pistons headman longtubes 1.5 roller rockers th400 with 3500 stall with shift kit car is gutted for race 3.73 gears
Old Feb 5, 2007 | 03:48 PM
:barf:
First thing you need to do is to get rid of THAT thing. Get a Comp XE274. You won't BELIEVE how much better it will run.
Old Feb 5, 2007 | 07:48 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm running the Dart Pro One 200cc runners. They are just fine on my 355 build up. I also have the 64cc versions. I agree that they would be overkill for a relatively stock motor. So it depends on where you are going with the motor. See signature for details on mine.
tmellott89
Oct 14, 2015 02:06 PM
86z89iroc
Oct 5, 2015 01:04 PM
djmarch
Oct 2, 2015 10:41 PM
Chevykid810
Sep 28, 2015 12:57 PM
alpine247
Sep 16, 2015 05:25 PM
