engine stand bolts
Old Feb 11, 2007 | 01:42 PM
outlawracer's Avatar
Car: 82 camaro berlinetta/87 sport coupe
Engine: 87 LG4 305
Transmission: world 5speed
engine stand bolts
hey guys what size and lighth bolts whould i use to mount the motor the the stand. the motor is an old 305
Old Feb 11, 2007 | 04:46 PM
ghotachevy's Avatar
can't tell ya every stand is different the have these things called tape measures u want the bolt in the block a 1'1/2" or so
Old Feb 11, 2007 | 04:55 PM
Gramps's Avatar
Car: 87 Camaro IROC
itll vary on the length depending on the manufacturer, youll have to measure for that, but for the threads, they should be a 3/8 UNC standard thread. take one of you bellhousing bolts to the boltstore with you and you can compare threads and sizes.
Old Feb 11, 2007 | 05:54 PM
grumpyvette's Avatar
the vast majority use (4 ) 3.5" long 3/8" NC GRADE 8 bolts and youll need about (8) 3/8" washers to slide two on the bolts below the bolt heads before inserting them in the engine stands tool head.
btw two little tricks ,
first is to insert the bolts then from the engine side slide a 2" long section of 3/8" rubber fuel line , over the bolt, this keeps them centered and far less likely to fall out easily.
second mount the tool head to the block before lifting the tool head and sliding it into the stand, locking it in place ONLY after greasing the swivel heads bearing area.
and its usually a good idea to replace the cheap 18" leverage handle with a 36" long forged steel bar
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Elliswon
Aug 10, 2015 12:33 PM
