Whats is wrong?
Old Feb 12, 2007 | 09:41 AM
eruk's Avatar
Car: 85 iroc, 96 z28 ss, 03 Silverado
Engine: 305, lt4, lingenfelter ls2
Axle/Gears: 3.08, 3.73, 4.10
Whats is wrong?
The timing on my 305 is advanced 15 degrees. When i try on set it where it is supose to be it sputters and dies. When i go to shut my car off some times it will diesel out when i shut off the key. Also on start up my car shoots out a bunch of carbon. It has new plugs, cap, rotor, wires. Any ideas what is wrong?
Old Feb 12, 2007 | 09:44 AM
XxSgtReillyxX89's Avatar
Car: 91 Trans Bird
Engine: 3.1 MFI
Axle/Gears: Stock
you could have put the cap or rotor on wrong its not that hard to screw it up.
are you turning it in the right direction?
Old Feb 12, 2007 | 10:07 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
carbon ? liquid ?
if liquid then its fine its just condensation because it is cold out, most all vehicles do this
which way do you need to turn the distributor to set it to what you believe is where it needs to be ?
clockwise or counterclockwise ?
if clockwise is the way you have been trying to turn it then turn your idle speed screw clockwise some- if it is a carb engine
you need to give us more info
are you using a timing light ?
is your balancer in good shape ? the outer ring could have slipped, see if the rubber on it is in good shape and not missing chunks or falling out
if so then it may not be accurate and you wont be able to set your timing to the timing marks
you could set it with a vacuum gauge instead
Old Feb 12, 2007 | 11:20 AM
eruk's Avatar
Sorry its carb. The cap and rotor are on right. I have been using a timming light. I will try the idle screw and see what happens.
Old Feb 12, 2007 | 03:31 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
did you disconnect the timing advances?
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
