89 tpi sensor question
Old Feb 12, 2007 | 07:34 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I am in the process of building my new harness for my motor swap. Everyting works at this point, and the harness is done, exept for one minor detail. My 85 v6 has a seperate coolant temperature sensor for the gauge... The 89 tpi engine I swapped in does not seem to have a second sensor. I hooked the one sensor I could find up to my computer. Is there another sensor I am missing?
Thanks!
-Brendan
Old Feb 13, 2007 | 02:23 PM
smithtc's Avatar
IIRC, the guage sensor goes into the side of the engine block for coolant...the computer sensor goes into the block underneath the intake manifold in the front of the engine.
Hope this helps
Old Feb 13, 2007 | 03:43 PM
Toehead's Avatar
It does!
When I get home for the weekend I will try and find the coolant sender. Do you know which side it is on?
Old Feb 13, 2007 | 03:57 PM
Damon's Avatar
Driver's side cylinder head between # 1 & 3 exhaust ports. Singe wire jobbie that runs the gague in the cluster. Don't know if it has the same calibration as a V6 motor, though.
Old Feb 13, 2007 | 03:58 PM
smithtc's Avatar
For the guage? The 89 is on the driver's side...underneath the exhaust manifolds.
Hmmm. Possibly located on the head itself (?). I don't recall. I'll have to look later.
Old Feb 13, 2007 | 05:15 PM
Toehead's Avatar
Ok.. thanks for the help! even if the calibration is incorrect, it would be nice to have SOME feedback when starting the motor for the first time.
Thanks..
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
