what's it gonna take?
Old Feb 12, 2007 | 08:06 PM
slimmeh's Avatar
Car: 1987 Pontiac Trans Am
Engine: 355
Axle/Gears: 10 bolt gm
hey I got a basicly stock 305 and not really up to swapping engines right now and i was just wondering what kinda upgrades are good on a 305? (intake, Heads, carbs, cams) help me out! use to be a Mustang guy new to these chevy's!
Old Feb 12, 2007 | 08:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You have an '87 TA with a stock 305, (what induction on it now, carb?), and a 9" rear? Who put that in there on a stock 305??
How much power are you looking at? Want to step up to a 350, or are you planning on keeping the 305?
Fix the bottlenecks first, biggest grins/$ there.
We're talking exhaust, rear gearing, camshaft. Then maybe heads, and a performer RPM intake. Carb would be pretty low on the upgrade list, along with ignition. Not a lot of speed/$ on those.
Old Feb 12, 2007 | 10:06 PM
slimmeh's Avatar
Engine: 355
It's got a 4 brl carb and i put the 9inch rear end in it. I kinda want to keep the 305 for now theres other things i want to get done to it before engine swap I'm more or less looking for ways to make it a little more powerful and have some fun with the little honda rice burners around town
that and used 350's are hard to come buy in my area
Old Feb 12, 2007 | 10:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
In ontario? Uh, alright...
Does it have the stock Q-jet on it, or an aftermarket carb?
Either way, like I said, it's not the bottleneck, so I wouldn't waste any cash changing it. Do exhaust, it's still useful after you inevitably swap to a bigger motor in there. I'd avoid anything specific to the 305.
Old Feb 12, 2007 | 10:42 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Buy Hooker 2055's and a 3" catback of your liking. Then for $100 I will port your intake manifold :P but you pay return shipping!
You have a roller or flat tappet cam?
Old Feb 13, 2007 | 09:57 PM
slimmeh's Avatar
Engine: 355
It's got the stock Qjet and the exaust has already been done.
I want to build a 350 maybe threw the summer and next fall but finding a block in my area is a challenge but if u know of anyone who has a good block for sale for a decent price please send them this way
Old Feb 13, 2007 | 11:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
I'm not wise to ontario, but F-bird'88 is in ontario, and there is a board for that region. Maybe ask there. I would just drop by a pick-a-part, they would have a complete motor for $130. Or ask the local machinist for a machined 350 block. Realize the machine work is done, so the price of $700 or so is quite fair. etc etc.
I think an '87 with a carb would be flat tappet, but i'm not totally sure. That's definately a good upgrade there.
Old Feb 14, 2007 | 12:13 AM
Gramps's Avatar
Car: 87 Camaro IROC
bore the block out .060", get new heads and a thin headgasket. update that stock intake and carb. get some headers and cat-back system. after those mods youll be in the hole 5G's and have a 450lbs/ft car...true story. but if your on a budget...you dont have to do that boring job.
PS: hows the weather in ontario
Old Feb 15, 2007 | 07:44 PM
slimmeh's Avatar
Engine: 355
Thanx for the advice gramps lol the weather here sucks cold as hell like -25 for 2 weeks straight snow like everyday kinda want the snow to be gone and spring to rise
Old Feb 15, 2007 | 07:58 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
I spent $650 on my LB9 Iroc, and did the following upgrades:
LT1 Cam
LT1 Roller Lifters
Comp Valve Springs
Ported TPI Plenum
Air Foil
Edelbrock TES Headers
3.42 10 bolt rear differential
G92 Oil Cooler
Taylor Ignition Cables
MSD Distributor Cap & Rotor
MSD Blaster Coil
Car should dyno around 195rwhp, and about 275rwtq
Not bad in my opinion. I did the complete cam swap myself (im 16) with the engine in the car, and bolted all of the parts on.
Old Feb 16, 2007 | 03:47 PM
slimmeh's Avatar
Engine: 355
lol sheldon u must be proud to have done all of that work yourself at the age of 16. but did u pay 650 for the car or the upgrades cause i'm sure those heads cost more then 650
Old Feb 16, 2007 | 11:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There's a thread on the FAQ forum about the differences between 305's and what to do to improve performance.
92projectcamaro
Dec 8, 2015 12:25 AM
Zane Story
Oct 8, 2015 12:40 PM
91 SrS
Oct 7, 2015 04:32 PM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Vincent135
Sep 28, 2015 10:50 PM
