Break in oil
Break in oil
Valvoline recomend all fleet sae 30 http://www.valvoline.com/pages/produ...sp?product=106
Its a diesel oil.
Any experince with that?
engine is a rebuild 355 with hyd/roll cam
Its a diesel oil.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
an diesel oil would work out well. Shell rotella is what we use in the states, but that fleet sae 30 sounds like a good choice as well.
Transmission: 4L80E/4L80E
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
It is fairly close. The good thing about diesel oils is that they have the extreme pressure additives that were long ago removed from automotive oil by the enviro-police.
These additives help in a new engine, where there is certainly extreme pressure.
Another option is for you to get GM EOS (engine oil suppliment) at a gm dealer , or online. It will also replace the missing additives.
There are no more extreme pressure situations with break-in than there are with running, with a roller-lifter engine. You want the rings and cylinder to run in with each other, which is why you use petroleum-based oil vs. synthetic.
The anti-wear additives that were removed for emissions reasons have to do with shear, which is the flat-tappet situation. Yes, ring-to-cylinder is shear, but it's not extreme pressure.
And it wasn't "eons ago". The GF4 spec came out in 2004, and was enforced beginning in 2005.
Okay, "long ago". (Sometimes I read too fast; the brain mixed the time reference with the enviro reference and came up with "eons".)
There was a zinc reduction back in the 80's that caused some problems with German Ford OVC 4-cylinders. But, the latest reduction that has caused more general flat tappet problems was very recent.
Aftermarket cam quality is another issue that has been problematic in the last 10 years or so.
Car: 92 Heritage T-Top
Transmission: 5-Speed
Since it's a roller cam...just be sure not to use any kind of synthetic oil when you break it in or it will wear the lobes on your cam flat as a pancake.
Actually, that can happen if you break in a flat tappet cam with synthetic oil. It won't happen with roller lifters.
Thanks for setting me straight. Thread
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Was off in lala land...it's quite nice there sometimes...
