400 vs 350
Old Feb 14, 2007 | 08:12 PM
gimpeh's Avatar
400 vs 350
hey there
im still debating on the engine i want, but I wanted to know what the major differences between a 350 and 400 SBC was ( aside from ci)
Is there any *possible way* i can get semi decent fuel economy out of a 400 SB? If for instance i put fastburn vortec heads on it)
any ideas?
Old Feb 14, 2007 | 08:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
stock cam, sure
do some mods....then they will all suck, if you want economy buy a cavalier....the difference between the 2 motors all built up can't be more than 1mpg if that while day to day driving
Old Feb 14, 2007 | 08:30 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
If you want mileage get an LS1.
Old Feb 24, 2007 | 02:04 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i drive a stock 400 with remanufactured Q jet carb and i can tell you that it eats gas, and alot of it, so it is not driven much anymore
if you are after gas mileage then you want a smaller engine for sure
good luck
Old Feb 25, 2007 | 01:27 AM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
go for the 400 when my 350 goes thats what im building for about $3,000 i can put together a 500hp at the crank motor that can take a beating all day long and not break a sweat
Old Feb 25, 2007 | 02:09 AM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
one thing with 400's....though i dont know how hard yours will be run, when we build them as race engines....we ALWAYS plumb the intake from the water jackets right at the front by the thermostat...back to the back two cylinders with some braided lines....for some reason...the 400 blocks dont cool the back two cylinders as well as the other 6....the back 2 always overheat and burn up. not that its any big deal...but something to keep in mind if it'll really have the ballz run off of it.
Old Feb 25, 2007 | 08:49 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by gimpeh
hey there
any ideas?
This is a good topic for debate. It depends on the horsepower level and the type of fuel you plan to burn.
Another thing to think of it is not just the gas mileage but the price of octane.
If the engine is to only use 87 octane gas, then a mild 400 would probably yield more horsepower per mile per dollar than a 350 of the same power level.
Here's another way to look at it: If both a 350 and 400 were built for 375 HP the 350 would probably get better mileage at cruise than the 400 but would need 91 or 93 octane gas. Like Xpndbl3 said: Both will get close to the same mileage. And like Nelapse said: the only way to get decent mileage with a high horsepower level is to use a newer technology engine.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
