I just replaced my FP. Here's some info.
Old Feb 19, 2007 | 06:54 AM
boomr's Avatar
I didn't think it was the FP cause on board diagnostics didn't detect a pump prob. and I could hear the (elec) FP running when I'd turn the ignition. But it was the FP.
Symptoms: white exhaust, engine surged and loped bad(barely drivable), backfired, stalled, eventually wouldn't start.
Shop wanted $500, Did it myself. New pump was about $80.
I cut an access hole in the trunk and had to splice the lines but it was worth it.
92 Fbird, 3.1, MPFI
Old Feb 19, 2007 | 09:52 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
which lines did you splice?
did you use high preassure fuel hose? and put hose clamps on it?
Not sure how a White exhaust means fuel pump...normaly that means you are sucking water or coolant... which would explain the engine surge and the lope, the backfire, the stalling, and not starting
did i miss anything?
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
MJS422
Oct 13, 2015 03:53 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
