Ignition Wiring? or solenoid?
Old Feb 22, 2007 | 09:13 AM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
Ignition Wiring? or Ignition solenoid?
Hey guys, i already tried to use the search, it didn't clearly answer my question.
My question is: when i turn my ignition (at the column) to the on selection and try to turn over the engine, it does everything but get power to the starter. I have replaced the relay in the kick panel and no luck.
No security light is popping up.
I have been driving with this problem for a while, meaning that i can start the car via the starter solenoid in the engine bay while the key is in the "on" position.
when i turn the key to start, the cd player turns off for a sec just like if i was going to start the car normally.
so, should i just test the wiring from the column to the relay, and after the relay? there are 2 wires... tan? and white? i think. if i spark those 2 together, should it give power to the starter?
any other information would be great. I have both the chilton and the haynes manual, but personal experience is always better than the book... it is technical versus simple.
Thanks!
ScottieB
Old Feb 22, 2007 | 05:46 PM
ScottieB's Avatar
Car: Blue 89' RS
Engine: 5.7L
bump
Old Feb 22, 2007 | 06:17 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
check the neutral saftey switch. its attached to your shifter. if its not making it wont allow the starter to work.
Old Feb 22, 2007 | 06:29 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
And don't forget the ignition switch and the rod from the key cylinder that goes down to the switch. I believe there is something that wears (especially with a tilt wheel) on the 3rd gen. If the cylinder and linkage don't move the switch all the way it will do as you describe also.
jklein337
Sep 19, 2018 06:23 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Accerrito22
Aug 23, 2015 07:22 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
