Need help with fuel lines.
Old Mar 1, 2007 | 06:00 PM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Hey everybody, long time no talk. Havnt run the ROC in awhile. Getting around to running it again and noticed rubber lines between steel fuel lines on fender and fuel rail going to runners were cracked. I need to know what adapters I need to run briaded hoses as GM no longer carries these hoses, at least not the high pressure side. I think I need a 6-AN adapter. How many adapters do I need and how much length in hose. You guys have always helped out before so I turn to you. Thanks again, any help really appreciated, I wanna get this thing on the road again and not worry about FIRE.
Old Mar 1, 2007 | 07:08 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
the supply is 3/8th inch and return is 5/16th
I have not found a fitting yet that worked well with from the hardline to an hose. They most certainly exist but I have been searching for exact PN's for my own setup.
Old Mar 1, 2007 | 07:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Accel P/N 74730 has one 3/8 Saginaw to -6 AN adapter, and one 5/16 Saginaw to -6 AN adapter to connect the hoses to the fuel rail. On the hard-line end, you could cut and reflare the tube to -6 AN and -5 AN with a tube nut and sleeve, and use a -6 AN to -6 AN and a -6 AN to -5 AN union.
Old Mar 1, 2007 | 07:33 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
That is to mate to the rubber lines. The rubber lines are female on both ends.
The hardlines are male ends. So we need female sag connectors.
Old Mar 1, 2007 | 07:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The adapters are for the fuel rail. I'm talking about replacing the rubber lines and the hard lines under the throttle body. If you don't want to replace the hard lines, cut and reflare them to AN.
Old Mar 1, 2007 | 08:28 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
http://www.holley.com/9894DBHERL.asp
http://www.holley.com/9894DBJERL.asp
I used both of these on a TPI sending unit to go to braided stainless. If it's the same end up front then these should work.
Old Mar 1, 2007 | 08:46 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
This is precisely what I am talking about thanks. However those links are for the same product.
what is the other size?
Old Mar 1, 2007 | 08:54 PM
Lo-tec's Avatar
Look at them again. One is 14mm and one is 16mm, both -6 AN.
Old Mar 1, 2007 | 08:55 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
i need to learn this stuff...
Old Mar 1, 2007 | 09:17 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
I was throw off. Look at what the shown script is for the hyperlink. They are identical. Good call
Old Mar 1, 2007 | 09:39 PM
Lo-tec's Avatar
one is DBH and one is DBJ
Old Mar 2, 2007 | 05:06 PM
Car: 1986 IROC-Z
Ok, went today and had to order those adapters through Murrays. I ordered 2 of the DBH & DBJ Earls. When they come in I'll go ahead and get the Braided fuel line and connectors that go with it. Hope this works. Wanna drive the ROC around again.
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
Dialed_In
Aug 20, 2015 01:45 PM
AkDrifted
Aug 17, 2015 07:45 PM
armybyrd
Aug 10, 2015 09:23 PM
