Is this true, and why is it?
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
Taken from http://www.goingfaster.com/spo/modthel03.html
Whoever has the most torque wins. Period.
In a otherwise identical car, take two bone stock, identical color, options, etc. '89 Camaro RS's and put in two 305 engines. In one RS, the engine is tuned for horsepower, let's say it makes 300 horses and 200 ft/lbs. of torque. In the other RS, we have a engine tuned for torque. Let's say it makes 200 horsepower and 300 ft/lbs. of torque. Guess which one is going to be faster ...? Right. The 200 horsepower, 300 ft/lbs. torque car will run away from the 300 horsepower / 200 ft/lb. car all day long, without effort.
Hands down.
Discuss...
Hands down.
Discuss...
Car: 1990 Camaro RS
Engine: 305 TBI (LO3)
Axle/Gears: 3.08
Horsepower is derived from Torque over Time. I say Horsepower wins brags torque wins brags but this discussion could go on forEVER!! If you want to get a little more in depth than that, torque is important... as well as what rpm you make it at. (I'm guessing and making assumptions... Hopefully I'm right) If you make tons of torque down low but falls off at 3500 rpm you are going to have to shift too soon to make up for the loss of high end torque. If you shift at 5 grand, you'll have a shoddy time if trying to win the race you're in.
Anything you read on Black Echo's old cobweb is suspect. He didn't know what he was doing or what he was talking about; and when he finally gave up trying to turn his hallucinations into anything resembling fact, he didn't bother to take that crap down. So be REAL CAREFUL with it. It contains some truth; but it's not "true".
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Another oversimplification.
The way I was told years ago was that torque gets you going and hp keeps you going. This leads me to believe that, all things being equal, the higher torque vehicle will get up and go quicker but the higher hp car will end up outrunning the torquemobile.
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
Gears play a big role in this as well. A torque heavy engine needs a tall gear (lower numerical) to put down a good amount of speed over a narrow RPM range. A car with a lot of top end needs a shorter gear to quickly reach its powerband, and since gears multiply torque, shorter (higher numerical) gears can make up for a lack of lowend torque. However, taller gears will not make up a lack of horsepower, which is why higher horsepower usually wins.
Transmission: 4L80E/4L80E
NHRA is trying to keep top fuel dragster speeds down for the sake of safety. They limit engine RPMs to accomplish that goal.
Now, think about it - would ET's be higher, or lower if they didn't limit RPMs???
Car: 1990 Camaro RS
Axle/Gears: 3.08
One controversial topic at a time. I agree though, makes you wonder what "would" happen. Supreme Member
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Race a "300HP" diesel truck and find out
All 600ftlbs of torque of it
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Horsepower sells cars, torque wins races. Again an oversimplification, but it does hold some truth. Horsepower is a measurement derived from torque. The higher RPM at which you make your peak torque the more peak horsepower you will make.
