Water Pump Question
Old Mar 3, 2007 | 09:33 PM
dc_sniper9130's Avatar
Car: '84 Camaro SC
Engine: Swapping in a 305
Transmission: 700-R4
Axle/Gears: 3.23 One-Wheel Sqealer
Water Pump Question
Hey all,
I'm building a 350 and was wondering whether to put a long or short water pump on. Thanks for the help,
Tony
Old Mar 3, 2007 | 11:01 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
well unless you plan on running the old school driver side alternator setup that was before 1969 then you need to get a normal everyday common long pump
i assume you are talking about SBC here
this is a short pump i have laying around here for SBC:
and here are pics from the internet of a car with its original short pump setup
they were installed from factory only on:
68-older cars
72-older trucks
and 74 or 75-older vettes
Old Mar 3, 2007 | 11:04 PM
Car: '84 Camaro SC
Yeah, its a SBC. And whichever is the simplest to build. I'm assuming that's still the long pump?
Also, would using a high-flow pump cause any problems?
Old Mar 3, 2007 | 11:22 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
oh BTW my alt is on the drivers side? i must have a back to the future camaro...
Old Mar 3, 2007 | 11:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Your car, like every car built since 1969 that isn't a Corvette, came with a long water pump. If you changed to a short pump, you'd have to replace all your accessories and mounting brackets to match.
The alternator went back to the drivers side on serpentine belt setups.
Old Mar 3, 2007 | 11:50 PM
Car: 91 RS
Engine: 350 vortec
i know.. was hoping my car was special
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
