i have problem need help???
Old Mar 3, 2007 | 10:58 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
Ok I think something is bad wrong.
i had a bed tcking on # 6 intake rocker i reset my valve lash yesterday . It ran great then I went on the interstate and then went to the dragstrip and it starting ticking loudly, and check it again and try tight it again and it start making a louder sound and so i turn it off and put it on a rollback took it home anyone have any ideas if it has a falt lope or the lifter has failed?
and i check the pushrod its fine
no oil coming out of the rocker arm hole
Old Mar 3, 2007 | 11:17 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
they are hydraulic flat tappets? you have to much preload on it you need to align the crank so that the valve is completely closed then tighten the rocker til it is just barely putting pressure on the rod then a full turn more but less is better anywhere from 1/4 to 1/2 is good
or there is something between the valve body and plunger take it apart and clean in solvent dry with air
Old Mar 3, 2007 | 11:59 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
if its a solid, then sounds like premature lifter/lobe wear.. if it keeps going on any longer, rebuild..
Old Mar 4, 2007 | 10:38 AM
intex1982's Avatar
they are hydraulic flat tappets and i did that and 6 int. keeps on ticking i set in to 3/4 it was fine for about hour of drive then it started again
Old Mar 4, 2007 | 01:20 PM
Car: 91 RS
Engine: 350 vortec
well then the lifter has probably colapsed you need to replace them all and i would probably swap cams now too as you are already gonna have to take it apart
Old Mar 4, 2007 | 04:18 PM
5678TA's Avatar
Car: 1984 Trans Am
cam and lifter are gone.. do a full rebuild.. just to make sure.. if the bearings are SMOOTHE, then you can reuse them.. if there is any sign of abnormal wear, change them.. any metal shavings, clean out the block..
Old Mar 4, 2007 | 09:39 PM
intex1982's Avatar
the cam is shot im going to rering the motor and have new cam bearings put in and cleaned so any metal shaving can be got out and put a new cam lifters in it
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
