What's needed for a OEM roller cam setup
Car: '91 Firebird
Engine: 305 TBI
I may be able to get a 1993 350 that should have roller cam provisions. I'm sure it has a flat tappet cam since it was in a truck. I've been looking on ebay, and I see kits with all the OEM stuff (lifters, spider thing, dogbones, etc). Will I have to get the block machined or anything? Will I need a different timing chain set and new cover? Any help or advice would be greatly appreciated. Thanks.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
really that all depends on the block... if the spider bosses where tapped if you have provisions for the thrust plate yes if you use the thrust plate you will need a different timing chain...if you dont you need a new timing cover and a cam thrust button
Transmission: 4L80E/4L80E
The chances that a truck block was machined for the roller cam provisions is pretty slim. Best way to know is to look at it. If it wasn't machined, it doesn't make much sense to have it machined - a lot of money for very little benefit.
Car: '91 Firebird
Engine: 305 TBI
Nah, I don't plan on machining anything myself. I thought that most blocks from 1990 on had roller cam provision, but some of those still had flat cams(mainly the trucks). What cars came with roller cammed 350's?
Terrell351
Jun 13, 2021 01:13 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
