Max compression ratio with 87 octane
Old Mar 5, 2007 | 10:30 PM
avst03's Avatar
Car: 83 GMC G3500
Engine: 350 w/ EBLFlash and TBI heads
Transmission: TH400
Axle/Gears: 4.56
What is the maximum safe compression ratio you can run on 87 octane pump gas?
83 350 chev truck motor with 083 heads and TBI fuel injection.
Mike…
Old Mar 6, 2007 | 12:33 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
About 9:1 or so. Depends on the cam, but assuming a small one, 9-9.5:1.
If you're loading it doing with a lot of weight, *cough*, then i'd stay VERY conservative on it, and look at a very good cooling system above all. (ie, bathtub sized radiator).
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Gordonr1973
Sep 29, 2015 11:59 AM
Vincent135
Sep 28, 2015 10:50 PM
