engine balancing
Old Mar 6, 2007 | 02:31 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
engine balancing
i'm guilding a sbc 400
wondering if its imparative to balance the engine internals?
the crank is a scat 9000
forged scat i beam rods
forged flat top srp pistons
also what does it mean when they say internally balanced and externally?
I've always been lead to believe that they wouuld add weight or take weight away from the flywheel or balancer if externally balanced,
and if internally balanced, from the crank shaft etc
cheers
blake
Old Mar 6, 2007 | 02:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A rotating assembly with a new crank should be balanced.
Internally balanced means all the weight necessary to balance the rotating assembly is located on the counterweights inside the engine, and the flywheel and damper are neutrally balanced.
Externally balanced means that some of the balancing weight is located outside the engine on the flywheel and damper. The flywheel and balancer themselves don't have to be altered from their stock specs.
Old Mar 6, 2007 | 02:48 PM
Tranny's Avatar
Car: 87 Trans Am
Engine: 434 being built
Axle/Gears: 3:73
I was told...
I was told that the old 400 cranks weren't balanced so they did it by special dampers. But if you buy a internal balanced crank then you can go with internal balanced parts. I would still have all the parts balanced together before you build the engine.
Old Mar 6, 2007 | 03:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
When GM made the 400, they weren't comfortable putting a 5.7" rod in it, because this would have raised the wrist pin too high, so they used a 5.454" rod instead. Shortening the rod meant there wasn't enough clearance to put large enough counterweights in to balance it internally, so they put the weight on the damper and flywheel.
A 400 can be internally balanced though, by using a longer rod with an aftermarket crank and pistons, or by adding heavy and expensive Mallory metal to the counterweights.
Old Mar 7, 2007 | 05:09 PM
Tranny's Avatar
Car: 87 Trans Am
Axle/Gears: 3:73
good
I am putting together a 434. I've had the mains spayed and went with the Eagle esp "H" beam rods and crank. This should really stroke!
Old Mar 7, 2007 | 05:29 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
have your mains spayed or neutured this is bob barker saying soo long
Old Mar 7, 2007 | 05:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Racing engines should never have their mains spayed as it tends to reduce their aggressive tendancies and makes them prone to sitting in the driveway getting fat and lazy.
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
LT1Formula
Nov 16, 2015 01:13 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
