Will a right hand oil pan fit on a left hand block?
Old Mar 7, 2007 | 06:08 AM
OneLeetIrocZ's Avatar
Car: 1988 Iroc-Z
Engine: 388 Stroker
Transmission: T-56 6speed
Axle/Gears: 3.45 9-bolt
Simple enough question........... can you put a driver side dipstick oil pan on a passenger side (zz4) dipstick block? will it bolt up without any leaks and work perfect? thanks.
Old Mar 7, 2007 | 07:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I doubt it. There is a bump out on the lip of the oil pan to allow the dipstick tube to go through the block and into the pan. My pass fill pan will not work on a driver side pan block. I would think that would follow suit with vice-versa.
Old Mar 7, 2007 | 11:33 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
No, it won't fit/work.
Old Mar 7, 2007 | 12:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
years were 55-79 driver side
80-85 pass side and two piece RMS
86-up pass side and one piece RMS
all differ from each other and wont interchange
good luck
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
