whats to high for use Compression
Old Mar 8, 2007 | 09:02 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
whats to high for street use and what ratio u need race feul is 12 to 1 to high and its not a daily driver
Old Mar 8, 2007 | 09:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes you can get away with 10.5:1 on iron heads with the proper camshaft lift and duration. Anything higher is typically 100+ octane
Old Mar 9, 2007 | 12:03 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, 12:1 means you're going to be mixing up your own race gas in your garage every time you want to drive it. It'll cost a fortune to drive.
FormulasOnly
Jul 23, 2018 08:47 AM
sammy52401
Nov 11, 2015 07:20 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
