Piston Ring Orientation ???
Old Mar 9, 2007 | 07:50 AM
gclay's Avatar
I am rebuiding an engine for the first time in 35 years. I am trying to be careful.
If you put the rings in upside down, can this cause problems?
I know that the second (thick) compression ring has a dot that must be mounted on top.
I cannot tell that one side is any different from the other for the thin compression ring. Is there a difference between top and bottom for this ring?
The oil ring has some little etching on one side and not on the other. Does this imply that one side is top and the other bottom? How about the rings that go over and under the oil ring?
I appreciate any help that might prevent me from doing someting disasterous.
Regards,
George Clay
Old Mar 9, 2007 | 08:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've been told all marks and bevels go up. I've rebuilt 4 engines and on only 2 sets of rings were there marks and/or bevels. The ones without marks apparently can go in either way. I have had no problems to date with any of the engines.
Old Mar 9, 2007 | 08:06 AM
F-Body Demon's Avatar
+1 Of the engines I have built all marks go up. and I always staggered the alignment so if you wre looking at the engine from the front the number 1 top ring would face left and then the second ring would face right etc etc
Old Mar 9, 2007 | 08:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Yeah. Probably should've added that. I 180deg the 2 compression rings. I even 180deg the two oiling rings which concurrently are 45deg to the compression rings.
Kinda like 3, 6, 9, 12 o'clock for each opening of the rings.
Old Mar 9, 2007 | 08:29 AM
gclay's Avatar
Thanks,
It would be really bad to put a lot of work(and money) into the engine, only to have it fail, because I put the rings in wrong.
I plan on following the diagram for stagering the rings.
I am guessing, that only the thick compression ring has a top/and bottom.
Regards,
George Clay
Old Mar 9, 2007 | 11:08 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
I've been doing a lot of research on all the little "tips & details" I'd need to know to build my 383, & here's one of the little things I've found...
i actually talked to total seal about this today, they said on average their rings rotate at about 18rpm. Im using their conventional rings btw.
also they said that alignment doesn't matter as long as the gaps are not aligned when you put them in. they said a rough 180 is good.
I'd think that the top two rings would rotate at a different, probably faster rate than the bottom (oil) ring, but as long as they're 180° or so apart, they should rarely if ever line up...
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
