knock sensor/fan switch...which wire is which?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Ok...Im trying to wire my HSR project and I need to run the knock sensor wire to the drivers side where I have already got the sensor...but I cant remember which is which, the black wire or the yellow wire connector..I forgot and I didnt take a picture of it when I removed it.....so can someone with an 87 help me out here?
thanks
thanks
that wire is yellow with the black connector..unless its just dirty as hell and im seeing yellow....
I want to make sure before I go cutting the wire and splicing some to it so I can route it to the drivers side..
are you sure?
are you sure?
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
To be sure ground the other gray connector with a black wire with the key on and the heavy-duty coolant fan should turn on.
If you don't mind my asking you should be able to mount the KS on either side, why the driver side?
ah...yeah but I dont have any power to the car....nothing is wired..NOTHING...fuel lines wide open ...n Im not going to put power the the car and let the fuel pump start pumpin....i wanna know which wire to cut/splice so I can get that one outta the way so I can route my starter wires.
the reason for the knock sensor on the drivers side is because there is no room on the passenger side with long tube headers...the knock is WAY to close to the headers and no room for the connector...the drivers side theres all kinds of room.
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
According to your year and engine the white wire is knock sensor. and the black wire is for the secondary fan. Autozone had free wiring diagrams on their website.
But anyways i just had the same delema with my wires they were both unplugged i found under the car and sure enought black wire for 2nd fan and white wire for knock.
You can also do that grounding test but i saw you dont have ne thing hooked up... Well good luck.
