Ignition Cylinder
Old Mar 16, 2007 | 04:35 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Ignition Cylinder
How hard is it to fit a new ignition cylinder in a third gen (1982 car). I was looking at the steering column and it looks to be one piece where the ignition cylinder is.
I bought an aftermarket cylinder on ebay, I hope that these are as good as OEM and fit properly, anyone any experience with them. I wanted to buy OEM but no seller would mail it to Ireland so I had to go with aftermarket.
Gerry.
Old Mar 16, 2007 | 05:16 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
hi there you need to pull the steering wheel and steering lock plate and turn signal switch assembly and then there is a torx head retainer screw pin that keep the lock in the column housing
need a steering wheel or pulley puller, and a lock plate compressor, both about 15 bucks USD at any auto parts store
good luck
Old Mar 27, 2007 | 05:24 AM
gholian's Avatar
Engine: 2.8 V6
Re: Ignition Cylinder
Thanks for The Information Randy. It sound like a lot of work. I have a steering puller which I bought in the US last year but I don't have a lock plate compressor. I will try and order one but most places won't ship outside the USA.............. this is an ongoing saga.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
FormulasOnly
Jul 23, 2018 08:47 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
