somthing blocking the oil pan!!!!
Old Mar 17, 2007 | 10:20 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Transmission: th 700 r4
Axle/Gears: stock
I think it the main bearing blocking it......... i have my tranny and flywheel off and i thought that it might be a good time to fix the oil leak i have coming from my oil pan........ but when i went to drop the pan its hitting and i cant menuver it out of the way...... so i think i have to raise my engine a few inches but i really dont want ot do all that....
what else can i do ????????????
Old Mar 17, 2007 | 11:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Raising the engine is the only thing you can do, aside from dropping the K member which would be a whole lot more difficult.
Old Mar 17, 2007 | 11:54 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
If your in a jam, put a long board or boards across your fenders and you can use a simple small floor or bottle jack to lift up motor enough to get the pan out. [once ya unbolt motor]
wider the board or boards the better, done it with lots of cars and the weight is always spread out plenty enough that you won't hurt anything even with a couple of 2x4 but wider is better.
Old Mar 18, 2007 | 04:16 AM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
should i use a hoist or two floor jacks one and the back and one under the harmonic balancer or what???
Old Mar 18, 2007 | 11:44 AM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
this mottor wont tip over sideways if i lift it from the Harmonic balancer and back behind the oil pan
Old Mar 18, 2007 | 01:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'd probably use a hoist or a chain block, and lift it until I could get some blocks of wood between the engine mounts and the block.
Old Mar 18, 2007 | 06:09 PM
Chevyman84's Avatar
Car: 84 Camaro
Engine: 355 or 5.7
Axle/Gears: stock
I got it i just lifted it up from the rear by my oil fliter enough to wear i could unbolt the oil pump and i got it.......
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
mrdevontay
Sep 2, 2015 08:04 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
