how much horse power?
Old Mar 19, 2007 | 04:02 PM
ripdanny6262's Avatar
How much horse approx would a 305 with forged pistons bore over a decent amount,also forged rods,a mild cam,no bolt-ons or anthing like that and its carberated, the motors all stock besides internal, all external stock how much horse would it be making?
Old Mar 19, 2007 | 04:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Slightly less than stock.
Old Mar 19, 2007 | 05:41 PM
how would it be less then stock, a stock what?
Old Mar 19, 2007 | 05:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Originally Posted by ripdanny6262
a stock what?
Exactly.
You haven't got nearly enough info in there to compare with anything.
Old Mar 19, 2007 | 05:50 PM
im asking how much horse will it have approxemently with the internal built but the external is not, heads are stock,headers are stock everything besides internal how much horse approx will it have as it stands with no external engine parts , its a chevy 305 from the mid 70's recently rebuilt.
Old Mar 19, 2007 | 05:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well stock cams can be considered "mild", so without actual cam specs no power gain could be estimated there. You haven't said if there's any compression change with the new pistons, so no power gain there either.
You did say that the pistons are forged though, which means they're probably heavier than stock so the increase in reciprocating mass would suggest that the engine would make less power than it did before the rebuild, all other things equal.
Old Mar 19, 2007 | 06:05 PM
gotcha so some boltons should boost it right like intake, carb,headers ext.?
Old Mar 19, 2007 | 06:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Intake and carb will get you next to nothing. Headers and exhaust will show some benefit though.
In general, good power comes from good heads (which any heads from the 70s most likely are not). Matching the cam to the heads ensures you've got a good powerband. The rest of the parts don't generally make you more power, they only cost you less.
Old Mar 19, 2007 | 11:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Well stated Apeiron.
The bottom end doesn't give you any power, so all the nice rotating parts only add durability, no HP. You'll need good flowing heads and a well suited cam to peg the HP number higher on the dyno.
'70's 305 heads are notorious for being crap. I think the '70's 305s were rated at or around 145HP. My '82 LG4 was 145HP, so I can only imagine a 70's one as being worse. So with your modifications, we can say around 125-130HP. Got beaten badly by any toyota echo's or anything yet?
Throw the roots blower on, or the 250HP nitrous shot and you'll be set
Old Mar 20, 2007 | 06:42 AM
not gunna waste time and money i will just throw it in while i build a 350 ha thanks guys
scottmoyer
Sep 5, 2015 09:33 AM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
