Name this intake!
Old Mar 19, 2007 | 07:42 PM
leeski's Avatar
Car: '82 Berlinnetta
Engine: Modified 350
Transmission: Turbo 350
Name this intake!
I bought this intake off ebay several years ago. I was told is was a Performer RPM and it obviously isn't but the price was right so I used it. A HEI disributer hits the runner so I'm guessing it's old, and it has mounting holes for both syles of carbs. There are no numbers to be found. I appolgize for the pictures, I know it's hard to tell with the carb bolted on. Any ideas? It serves the purpose but I think it falls info the "perfomer" catagory instead of the "rpm" catagory and if so I might be better off with something else.
I've been looking for a better rpm style manifold, like a Edel Performer RPM Air Gap, Weiand Stealth, or Holley Street Dominator. Are there any articles or personal experiences actually comparing these? I'm not looking for "I own this manifold so it's the best" comments. Thanks for any input!
Attached Thumbnails Name this intake!-dsc02419.jpg   Name this intake!-dsc02420.jpg   Name this intake!-dsc02421.jpg
Old Mar 19, 2007 | 08:04 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Too much stuff to see it clearly, but I'd say either a performer or 'stock type' weiand manifold.
Old Mar 19, 2007 | 08:14 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i dont think that is edelbrock doesnt say anything on the runner in front of the carb and doesnt look like it ever did and it would be thier Endurashine which i dont think was out that long ago
Old Mar 19, 2007 | 08:18 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Might be some type of Edelbrock, but I'd say it's not a Preformer.
Old Mar 19, 2007 | 08:51 PM
blizzted's Avatar
Car: 2000 tahoe,94 ex-cab,92 rs
Engine: 350,350,305
Transmission: all autos
looks like an older style z28 intake to me does it have the firing order on the front if so its a gm intake
Old Mar 19, 2007 | 09:06 PM
Car: 91 RS
Engine: 350 vortec
you would never get...or keep cast that shiny
Old Mar 19, 2007 | 09:12 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
doe sit say anythingt on it behind the carb or downlow in front of the distributor ?
at all
or anywhere
looks kinda like it bene blasted and polished
but thats just me
good luck
Old Mar 19, 2007 | 09:18 PM
leeski's Avatar
No text on it anywhere, including the bottom.
Old Mar 19, 2007 | 09:31 PM
leeski's Avatar
There's an odd looking small protrusion over the end of # 1,2,7, and 8 runners close to where it meets the head. You can see it in the second picture. Ring any bells?
Old Mar 19, 2007 | 09:35 PM
Car: 91 RS
Engine: 350 vortec
could be an edelbrock but not a RPM i havent seen those with both bolt patterns
Old Mar 19, 2007 | 11:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yea, it's a low rise dual plane of some type - like a stock one.
No magnet sticks to it right? It is AL?
Looks like someone took enough time to polish it up, it's seen some lovin' that's for sure.
Old Mar 20, 2007 | 08:29 AM
leeski's Avatar
So I'd definately be better off with something else, any suggestions between the three I'm trying to pick from? From what I've read, they are all good, and the Air Gap is more money. Thanks!
Old Mar 20, 2007 | 01:12 PM
Damon's Avatar
Re: Name this intake!
It looks old, whatever it is. I don't think any intakes (stock or aftermarket) have had provisions for an intake-mounted breather/oil fill is DECADES. That's the big hole in the front of the intake, down low, near the thermostat housing. Your is plugged, obviously, since nobody but the restoration guys use that location for the breather/oil fill any more, but that's where it would have gone.
See how your alt. top bracket is hacked-n-modified to fit onto that intake? That's common when you try to fit newer style brackets onto old style intake.
Old Mar 20, 2007 | 01:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They've always had polished intakes. Endurashine is marketing BS for some sort of protective coating they've recently introduced.
SP2P maybe?
Old Mar 20, 2007 | 02:17 PM
leeski's Avatar
I don't think it's a SP2P. Definately aluminum, checked it with a magnet. Any input on my new manifold selection? I'm leaning towards the Stealth, from what I've read I might have trouble fitting the Holley.
Old Mar 20, 2007 | 03:12 PM
StreetRod's Avatar
Car: 89 Supra
Engine: Tbi 350
Looks kinda like a Power+Plus Crosswind Manifold
Old Mar 20, 2007 | 03:18 PM
Definitely NOT the SP2P.
Not any of the old factory intakes.
I'm stumped. You're right, it's REALLY old; pre-69 kind of old. Having both sets of bolt holes but the thermostat housing where it won't support the earlier style of RH alt bracket, where the bracket went to a stud instead of a bolt at the pass side of the water neck, puts it between about 65 and 69 or maybe up into the early 70s, before the new style of brackets was important in the marketplace.
Old Mar 20, 2007 | 03:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Definitely looks dual-plane, though, so it's not a Scorpion or a Tarantula. Who else made aluminum intakes back in the day, Offenhauser?
Old Mar 20, 2007 | 03:33 PM
leeski's Avatar
Doing some research, is this the "Stealth" everybody likes? It looks like Holley as maybe renamed this one to a "Action-Plus" and now the new Stealth looks like a Holley Street Dominator?
Old Mar 20, 2007 | 03:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's even got the oil fill tube hole, so at least was intended for a 60's SBC. But it doesn't have the AC bracket holes, has those "nubs" instead - I've seen those nub bosses on factory intakes, but don't recall any use for them. Don't see a divorced choke mount, but that may be hidden. Appears to have the exhaust cross-over.
Really looks like a home polish job to me. Probably ground off all identification marking in the process to make it "cleaner".
I'd guess an early Edelbrock, but that's a pure guess.
Old Mar 21, 2007 | 05:16 AM
Pat Hall's Avatar
The "Action-Plus" intake actually resembles the mystery intake that's on your car right now. In fact, that's my guess on your mystery intake. The pic you posted is definitely the "Stealth" intake. My brother runs one on his 69 Camaro, and he's really happy with it. There should be no problem at all fitting a Holley on it either. In fact, Holley bought Weiand several years back, so of course a Holley will fit on a Stealth intake. My brother also used to run a Performer RPM intake, and he replaced it with the Stealth because he had to use a carb spacer on the RPM to be able to hook up his power brake fitting without it hitting his Holley carb. Edelbrock intakes are decent, but personally I've always preferred the Weiand/Holley intakes over them since I run Holley carbs, and they're basically designed with those carbs in mind. Edelbrock intakes are overpriced and more tailored for those junk, re-named Carter AFB carbs that they sell. Before anyone gets all excited over me dissing Edelbrock, keep in mind it's just my own personal opinion.
Old Mar 21, 2007 | 08:29 AM
leeski's Avatar
I like the Holley Street Dominator (300-36), but I've read a lot about having to use an old BBC drop filter base with a stock hood to clear. Is this true on an '82 Berlinetta?
Old Mar 21, 2007 | 09:06 AM
Engine: 400
Yeah the Street Dominator is a tall intake. I'm pretty sure you need some sort of drop base air cleaner.
Old Mar 21, 2007 | 09:20 AM
djr_678's Avatar
Car: 98 T/A 94 dodge ram
Engine: LS1/ 5.9
its a Professional Products Power+Plus manifold basically an edelbrock peformer
Old Mar 21, 2007 | 10:19 AM
Ummmm....no.
Here's that product; actually called a Cyclone Plus. No resemblance. Unlike the one in question, the PP one fits 69-up cars.
Old Apr 16, 2007 | 09:32 AM
leeski's Avatar
If anybody's interested in knowing what I ended up doing, the Holley 300-36 is a huge improvement over this manifold and fits with a 1 3/8 drop filter base.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
