HELP power window regulator nightmare
Old Mar 19, 2007 | 08:45 PM
blizzted's Avatar
Car: 2000 tahoe,94 ex-cab,92 rs
Engine: 350,350,305
Transmission: all autos
ok heres the deal i have replaced power window motors before but this one on my 92 rs is giving me hell,first of all the motor was riveted to the regulator i had to remove all the tracks and the reg. in the process the spring popped off and i lost a big chuck of my forearm at this point i almost busted the window but calmed down,so now i have all the crap took out its a good thing i dont drive this car daily so i just put it back in the garage what i need is any helpful info on the easiest way to reasemble im hoping i dont have the same probs on the pass side its messed up too.....thanks in advance...Steve
Old Mar 19, 2007 | 09:31 PM
Those are EXTREMELY EASY to replace.
ALl you gotta do, is drill about a ½" hole in the sheet metal, over each of the covered-up rivets; then drill the rivets out with a ¼" bit. Put the new motor in with the BIG aluminum pop rivets. Done.
It takes longer to get the door panels and the water shield off and back on, than to change the window motor.
You don't have to disturb ANYTHING ELSE when doing this.
If you've never messed with windows before, you're going to be spending a while getting it all adjusted back right. Take your time, be patient, don't button it back up until it's right.
Old Mar 19, 2007 | 10:49 PM
blizzted's Avatar
Engine: 350,350,305
well it wasnt just the motor but the regulator and the gears were all rusted up all the wheels and tracks look ok just the gear i have a replacement but getting it in is gonna be a B@#%!!! i might have to take the sawzall to some sheet metal and rivet it back will have see again tom.
Old Mar 20, 2007 | 07:26 AM
OIC...
Water isn't supposed to get to those parts. If they're THAT bad, it probably means the outer window felt has fallen to pieces. You might want to put in a new one of those while you've got it apart, to keep it from happening again.
Old Mar 21, 2007 | 01:16 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: HELP power window regulator nightmare
when ever i have to pull the complete assembly i clamp the regulator in a vice, to hold the gear in place while i do the motor i clamp the gear to the regulator with vise grips. don't tighten the vice too much, just enough to hold the regulator securely, same with the gear.
this site is about swapping from manual to power windows, but it has some pics of what the regulator should look like when you get the motor back on.
http://www.p71interceptor.com/thirdgen/powerwindows/
Old Mar 21, 2007 | 04:17 AM
Pat Hall's Avatar
Another tip that should prevent you from losing another chunk of your forearm when you go to do the other side. You should drill a small hole through the half moon shaped gear and put a small bolt or nail through the hole. That way, the gear has a positive stop when the nail or bolt touches the regulator assembly. This will keep the tension on the spring and gear when you disconnect the motor, so that the spring doesn't come flying off, or the gear pinching your fingers. Little trick I was taught a long time ago.
Old Mar 21, 2007 | 08:33 AM
blizzted's Avatar
Engine: 350,350,305
ok guys thanks for all the help will let you know how it goes i ordered 2 new motors yesterday through ebay got em both shipped for under 40 bucks just waiting on those now,heres another question what is the best way to get the regulators out i have tried all kinds of ways even tried to go through the top,but no dice im thinking they need to go through the bottum of the door on the latch side thats the biggest hole.hopefully when i got to do the pass side i wont have to take it out.those picts helped out alot denn thanks, see the spring in the center mine popped off do i need to take the assemble out to put the tension back on it or what? so now it looks like im just waiting on parts will post when i get it going again hopefully this weekend....
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
