Oil Cooler Removal
Old Mar 20, 2007 | 04:42 PM
brian schuetta's Avatar
Car: 83' Camaro, 88' TPI 350 Firebird
Engine: 383
Transmission: th350
Axle/Gears: 12 bolt w/ 5.13s or 4.56s
Oil Cooler Removal
Has anyone removed the stock oil cooler from there 3rd Gen? The one on my 88' Formula 350 has lines that seem to be the source of endless oil leaks. Has anyone had problems after removing one? I want to replace the oil filter pad with one without the hose connections.
Old Mar 20, 2007 | 04:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Cooler Removal
Those lines carry coolant, so they're not the source of your oil leaks. There's an O ring between the adapter and the block that might be, though.
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
3rdgenparts
Aug 8, 2015 07:09 PM
