heads on a 350
Old Mar 20, 2007 | 09:21 PM
jt2007's Avatar
heads on a 350
hey guys. I wanted to get some opinions on what type of heads i should put on my third gen. I have a 350 bored .040 over, w weiand intake manifold, speedpro cam, 600 cfm edelbrock carb. This engine produces alot of low end power. before i put it in i dyno'ed it and it put out 340 ft lbs of torque, and 280 hp. What head would go good for this application? thanks
Old Mar 20, 2007 | 09:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: heads on a 350
What heads are on it now?
Which pistons, flat top, etc?
Which cam do you have? (detailed specs please).
You've gotten pretty good dyno numbers, but you're definately being held back by your combo (cam, carb, maybe heads).
What kind of price range are you thinking?
Old Mar 20, 2007 | 09:56 PM
jt2007's Avatar
Re: heads on a 350
The cam: hydrolic roller cam, 460-470 lift, 288-284, its has the stock heads on it as of right now, dual plane intake manifold, roller lifters. As for the price range, im pretty open, i want to put on whats going to help the most, hopefully it will be around 1,000 or so...
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
