Engine/tranny out AND here it is ...
Old Mar 24, 2007 | 03:58 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Took me and two buddies 6 hours or so to disconnect it and take the combo out.
I still don't know for sure what made the engine loose oil, but there's a possibility the knocking sound didn't even come from the engine at all.
Took the starter off, noticed a bolt stuck inside, right in the gear, it had actually caused part of the casting of the starter to break off. So I had my suspicions, got it all confirmed when I removed the tranny dust cover, and YES indeed.
One of the flexwheel to torque converter bolts was gone, it had flewn off, right into the starter.
So it's quite possible the knocking sound came from that bolt coming loose, and that's also why the engine wouldn't start again, the bolt had jammed the starter.
However good thing I took the engine out anyway, since I'm sure several seals and gaskets were bad anyway, so at least this way I'll have a more reliable engine in with the tranny. (Cleaned out and changed gaskets on my other 305, more miles on it than my original one, but it looks good)
Old Mar 24, 2007 | 05:24 PM
Vader's Avatar
Re: Engine/tranny out AND here it is ...
Loctite 262 is always a good idea on TC bolts.
Old Mar 24, 2007 | 06:12 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Thanks, I was thinking about asking that one actually, what to use to prevent it from happening again.
Old Mar 24, 2007 | 07:09 PM
Damon's Avatar
The fatory star washer and proper torque has always done it for me.
Check for cracks on the flexplate- if you lost a bolt that might be either the reason why or the result of it happening.
Old Mar 24, 2007 | 09:16 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
I'll check it once we pull the tranny off, since my replacement engine doesn't have a flexplate nor torque converter on it.
How do you remove the oil stick tube from the engine ? Is it a twist in/push in unit ? Pull it out or tap it gently from the bottom ?
Old Mar 25, 2007 | 09:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
1 bolt holds it to the exhaust manifold. After that it should just pull out. Twist if you have to.
Old Mar 25, 2007 | 10:42 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
kewl
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
383backinblack
Oct 14, 2015 08:50 PM
gta892000
Sep 16, 2015 12:40 AM
