IAC question
Old Mar 11, 2007 | 09:37 AM
evoluzione1's Avatar
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
IAC question
I just set my IAC and during the setting when you start the car I have to floor the car to get it started and then tap the gas to keep it running, even after I turn up the idle speed. Am I missing something or do I have something else wrong. Is this normal?
Old Mar 11, 2007 | 10:42 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
if you mean the idle air control valve in the tbi unit usually you have to set them to about 1 and 1/8" length
good luck
Old Mar 12, 2007 | 08:16 AM
1991L98G92's Avatar
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Are you talking about the Idle Air Control Motor, or Minimum Air Rate?
First off, the IAC is not adjustable. The computer controls that. That's like saying I want to adjust my O2 sensor, and enrichen the Air/fuel mixture to make the O2 reading higher.
If you are talking about setting your minimum air rate, once set, it shouldn't die or have to hold the throttle open to start. It's possible you're IAC motor isn't working at all.
Old Mar 13, 2007 | 07:00 AM
Engine: 400 and 350
Yes I am talking about the IAC "idle air control valve" and from the tech page it talks about setting it, so that is what I tried doing. How do you set it up since it is not adjustable. I need input because now the car idles high and low based off the info on the tech page. Before setting the car idle real low when cold and sometimes died.
Any help would be great.
Old Mar 25, 2007 | 11:02 AM
1991L98G92's Avatar
Re: IAC question
You need to make sure the throttle plate butterflies and housing is clean of any carbon build up. Also, the IAC pintle also gets carbon build up on it. If the pintle, plates, and housing are clean, and adjusting the minimum air rate doesn't allow the computer to control the RPM, then there is another problem.
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
