car smokin
Old Mar 25, 2007 | 06:23 PM
cool84's Avatar
Car: 84 trans am
Transmission: built 700r4
car smokin
ok so yesterday when i started my car i noticed a little puff of smoke from the exhaust. so i think ok not that big of a deal, well this morning it was a bigger puff of smoke. then this afternoon i started it and a big puff of smoke came out and then a steady stream of smoke out the exhaust.
so i'm guessing my valve seals are gone, or maybe the rings or both. now i dont know what to do. i asked a friend and was advised to go buy a new engine since rebuilding the heads would be real expensive.
anybody have any idea how much it will cost to have new valve seals done? the motor sat for a few years but ran for 2 weeks before it did this. i have another 305 in pieces but those heads have been sitting fo a while too. what should i do? find a new motor or new heads instead of rebuilding mine. i have verry little money so this really sucks, i only have a few hundred bucks to get this problem fixed so i cant afford to just slap one thing in and hope it works. and another motor swap would suck *** since i'm so busy right now.
i'f anybodys got an idea on the cheapest way to fix the problem let me know
Old Mar 26, 2007 | 11:24 AM
cool84's Avatar
Car: 84 trans am
Re: car smokin
so i'm gonna try some stp stop leek later and see if that helps then i guess i'm gonna replace the valve seals in my 416 casting heads i have. anybody know where i can find some good ones to fit i have no idea how to work on heads so any advice or part numbers would be appretiated
Old Mar 26, 2007 | 01:33 PM
cool84's Avatar
Car: 84 trans am
Re: car smokin
will these seals work for my motor?
http://www.napaonline.com/masterpage...m+Oil+Seal+Set
do i just buy one set or two? i've never done anything with heads before so i'm really lost right now
Old Mar 26, 2007 | 05:15 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
Re: car smokin
you'll need 2 sets it looks like, 16 valves, only 8 o rings in the pic set. get a compression tester and check all the cylinders compression, when you find a low one, squirt an ounce or so of motor oil in the cylinder and retest, if the compression rises you have worn piston rings and valve seals won't help a thing.
Old Mar 26, 2007 | 09:45 PM
cool84's Avatar
Car: 84 trans am
Re: car smokin
i'll do a compression test on wensday since i have off. i added some stop leek and it seems to have fixed the problem so i dont think its the rings, hopefuly. i'll just keep an eye on my oil pressure and hopefuly it can last long enough that i can save up some more money and just get my other set of heads i have rebuilt and throw them and my performer intake on the motor.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
