Can fuel pressure regulator handle the pressure?
Old Mar 27, 2007 | 03:05 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Axle/Gears: 9 bolt 3.91
I just installed a TRE 255lph fuel pump, and I never questioned the pressure. I also installed a holley bypass regulator part#12-803bp. I'm wondering if the regulator can handle the increased pressure. It's working fine so far, but I don't want a fire. Also would 50 psi line be enough for the input line on the regulator, or is that a fire hazard also? If I need stronger line should I get the stock one that threads on at one end. thanks
Old Mar 27, 2007 | 06:26 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Can fuel pressure regulator handle the pressure?
My service manual states that the stock regulator can handle no more than 60psi.
Old Mar 27, 2007 | 08:13 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
I wrote an email to TRE, hopefully they can help. I'm probably just going to buy the stock feed line.
Viprklr, I have a holley regulator, I checked the installation instructions and it listed two regulators for use with a performance pump, one didn't have a return. I hope the diaphragm can handle it, otherwise I wasted 60 dollars.
Old Mar 27, 2007 | 11:37 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Can anyone help, I have searched over and over. I think that fuel injection line will be enough, from what I understand the pressure is determined by the regulator. I don't want to go waste money on the new GM line if I can get 5 dollars in line and use that. I'm also using fuel injection clamps, I don't want fires.
Old Mar 28, 2007 | 04:31 PM
tompumped's Avatar
Car: 88 firebird
Engine: 355
Transmission: t-5
Napa had 180 psi fuel injection line, i'm going to use that.
Old May 29, 2018 | 05:18 PM
88IROC-USA's Avatar
Car: 1988 IROC-Z
Transmission: 700-R4
Axle/Gears: 2.77 Positrac
If it ain't broke, why you trying to fix it?
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
