pete jackson gears???
Old Mar 27, 2007 | 04:44 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i got a set off ebay and they only come with one of the little Advance/Retard at Camshaft and i didnt now what that thing was till last night but i put it in and line the dots up other day. so should i take it back out and order some of them littles thing?
Old Mar 27, 2007 | 04:57 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: pete jackson gears???
huh? that is confusing
Old Mar 27, 2007 | 05:04 PM
intex1982's Avatar
http://store.summitracing.com/largei...g=cca-4760.jpg
those things i used the gold one i think and i advance it so sould that be ok???? and how much advace is that?
Old Mar 27, 2007 | 05:18 PM
Guest
Guest
Posts: n/a
Those say 2 degree increments, so if thats what you have its 6 degrees advanced or retarded depending on how you installed it. I would not leave it that way.
Old Mar 27, 2007 | 05:33 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Your not using that with a knock sensor are you?
Old Mar 27, 2007 | 05:56 PM
intex1982's Avatar
no computer!will the comp cam bushings work? what do does the maker of pete jackson gears mean when they say (Minor machining may be required) does 350 need it
no computer!will the comp cam bushings work? what do does the maker of pete jackson gears mean when they say (Minor machining may be required) does 350 need ant
Old Mar 27, 2007 | 06:20 PM
Guest
Guest
Posts: n/a
Dont know. You'll have to install it and follow the instructions and check clearances. Dont skip that.
The comp bushings will only work if the hole is the same size, I forget what size it is.
Old Mar 27, 2007 | 07:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The bushings will work with any gear set. You need to drill out the hole in the cam gear to 1/4" to insert a bushing. Buy a cam gear lock plate because it will sit over the bushing to keep it in place.
Gear drive is too noisy. I had a set in my car for one day before ripping it out and reinstalling a chain for the race the next day.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
