msd wires arcing everywhere?
Old Mar 27, 2007 | 08:19 PM
84camz28's Avatar
Car: 1988 IROC-Z/1996 DODGE RAM 1500
Engine: 350 L98 TPI/360 v8
Transmission: 700r4/46RE 4x4
Axle/Gears: 4th gen 3.42 10 Bolt Posi/3.90 posi
on my 91 formula 350 i have the msd wires and the blaster coil i noticed it running rough at idle so i popped the hood and saw a lightening storm lol. everything the wires touched they arced on. then i touched the wire on the coil and the coil itself started arcing lol.im not sure if the iwres and coil are shot or what lol. just wanted to know if my new wires are junk thanks
Ryan
Old Mar 27, 2007 | 09:17 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: msd wires arcing everywhere?
well a bad coil cant cause your wires to arc so... isnt it obvious
Old Mar 28, 2007 | 07:06 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Were they pre-terminated or did you put the ends on? If they are factory terminated then did you put some die-electric grease on all the boots prior to putting them on? That will make a difference in sealing the boots..
Old Mar 28, 2007 | 07:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What have you got your plugs gapped at?
stalkier
Dec 6, 2015 11:25 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
