OK the fun begins HELP
Old Mar 28, 2007 | 07:12 PM
89jim's Avatar
Ok after years of redoing my 89 GTA the fun begins. This has been a long project. (5 years) I finally have everything back together and have a few problems right off. Almost everything on the car is new . Engine,trans and all bolt on stuff, I put an adjustable fuel reg. on and when I turn the key on I hear the fuel pump run for a few seconds in the back. Thats OK but the gauge on the fuel rail only reads 25lbs. I turned the adjustment screw in a long ways and it only goes to 28lbs. Is that normal for a reading with the engine off? Next problem when I turn the key the starter does not do anything. I hear the relay in the car click and my gauge go up but nothing.Hear again new battery fully charged, new starter. Where should I start? Almost seems like a neutral safty switch problem ? I tried moving the shifter back and forth and tried it in neutral no good. Does it matter which side of the starter the small wire goes? There are two terminals right across from each other does it matter? I can see there is going to be alot of small gremlins to work out as I go. Any help is welcome. Thanks
Old Mar 28, 2007 | 07:31 PM
SebasIroc's Avatar
Car: Iroc-z 86
Engine: 350 4bbl
Transmission: built up 700r4
Axle/Gears: ls1 4.10 posi
Re: OK the fun begins HELP
try the other small terminal cause yes it does matter....i had this probleme when i first installed my engine.....its a free try. for the fuel its low, should be in the 40psi range but in no expert.
Seb
Old Mar 29, 2007 | 06:43 PM
89jim's Avatar
Yep, I changed to the other terminal and she turned right over.I started the motor for anbout 10 seconds and shut it right off. No oil pressure reading on the gauge. When I checked the fuel pressure reading on the gauge it was reading 45lbs. So that reading goes up for sure when the engine starts. Sat. I will have to see why I have no oil pressure.
Old Mar 30, 2007 | 07:00 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
If you really want to know what the oil pressure is then the best way is to temporarily hook a mech gauge to it.
Old Mar 31, 2007 | 12:06 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Static fuel pressure should be around 42 stock.
Is this your initial startup after the build? If so, you could have air in the fuel system causing low readings and your oil pressure may be nothing to worry about since you'll need to fill your oil filter and get the oil flowing through the system.
On my initial startup I had no oil pressure for about 30 seconds. I was crapping my pants.
Old Mar 31, 2007 | 03:04 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
Agreed. Just as a data point, when I turn the key on my '89 GTA, the fuel pressure rapidly climbs to the full reading (42, 46 psi, can't remember what it's set at right now). So if yours shows only partial pressure again, it's not "normal".
ZZ3Astro
Aug 13, 2019 12:57 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Marc Brown
Sep 28, 2015 01:40 PM
