car won't start
Old Mar 29, 2007 | 10:20 PM
gcmcmahan's Avatar
car won't start
checked and fuel injectors are only dripping fuel no spray.wanted to check i assume this is a fuel pump problem,would there be any other reason for this before i drop fuel tank?this is a 1983 trans am crossfire injection 305and yes never had a problem with crossfire injection with over 300.000 milesjust thought i would add that.
Last edited by gcmcmahan; Mar 29, 2007 at 10:24 PM. Reason: want enter yr of trans am
Old Mar 30, 2007 | 12:53 AM
PPM's Avatar
PPM
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
Re: car wont,t start
Have some one turn the key to the on position while you stand near the tank. If you hear the fuel pump come on which is a kind of hum then your fuel pump is working
I would check your fuel lines because a restricted/pinched supply line or bad fuel injectors can cause this also.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
