What oil should i use?
Old Mar 30, 2007 | 12:48 AM
PPM's Avatar
PPM
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
Is 20w50 to thick? If so what should i put in my camaro?
If it helps to know what conditions i live in... i live in California
Old Mar 30, 2007 | 01:54 AM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
Re: What oil should i use?
What part of California and what engine / mods etc.
I run Shell Rotella T 15W -40. It's meant for diesel engines but it has lots of zinc in it which protects against wear. It was recommended to me by a retired service manager for a Police Department, he swore by it.
When the motor was fresh I used Mobil 1 but I use too much oil now to use Mobil 1. That's one reason the rebuild is being scheduled.
Old Mar 30, 2007 | 09:41 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
be careful, factory small block oil pump drives have a nylon coupler in them, personally id be afraid to use 20-50 alone on a high mileage unit, and a 3:2 20-50 lucas mix in a low mileage motor due to the wear on the drive, but if you've replaced that shaft with an all metal one, id say go for it, also i wouldn't run it if the motor has a high volume oil pump because it would be more prone to sucking the pan dry with a heavier oil, also don't use a 10-40 oil as the polymers in it don't last like other oils
Old Mar 30, 2007 | 10:27 PM
PPM's Avatar
PPM
I live in the bay area in mountain view by san jose. It is cold and rainy in the winter and hot in the summer.
As for the motor i am not sure of the CID because i forgot to ask my friend i bought it off, but it is a 350 base either bored to a 355 or stroked to 383. It has alum. heads with 2.02 valves, Lingenfelter Accel Super Ram, Headers w/ sual high flow cats and 3" exhaust, MSD 6AL Box
Old Mar 31, 2007 | 01:03 AM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I would use Mobil 1.
Sounds like you got a pretty cool car. I am just a bit North of you. Stop by the Regional section under Norther California
Welcome to the board. Always nice to see new members!
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
