Vac selector no hiss top vents
Old Mar 31, 2007 | 08:44 PM
jim s's Avatar
My A/C is defaulting to the top vents. Pulled out the Vac selector and the the vac hose plug was pulled off. I put it back on and still the same problem. I’m not hearing any hiss. If this plug was off wouldn’t I hear a hiss? My car is an 83 with a 350 in it.
Thanks for the help
Jim
Old Apr 1, 2007 | 04:35 PM
quadrojunk's Avatar
Re: Vac selector no hiss top vents
You might not hear a leak, check the hard line under the hood to make sure it is hooked up. If it is you may need to pull the unit back out and start the engine to see if the line has vacume. If it doesnt you will have to find the break.
Old Apr 1, 2007 | 05:43 PM
jim s's Avatar
Is there a way to determine which is the main feed? Looks like the hoses are color coded.
Jim
Old Apr 1, 2007 | 05:50 PM
quadrojunk's Avatar
I do not remember the color of the main, I just know it when I see it. Oh that must sound bad. The other way would be to hook a vacume pump to the main line under the hood. If it holds pressure its fine. That one is easy to find. It is a hard line hooked into a vacume (Ball) on the right (passenger) side of the engine, with another hard vacume line leading to the engine intake.
Old Apr 1, 2007 | 07:27 PM
jim s's Avatar
Here is a shot of it. Maybe it will help.
Thanks for the help I'll start looking for that hose.
Jim
Old Apr 1, 2007 | 08:26 PM
jim s's Avatar
http://www.wegottafindearth.com/rpf/accolors.jpg
I found this image. Looks like the violet one is the feed line.
Jim
Old Apr 2, 2007 | 05:34 AM
quadrojunk's Avatar
Yes that violet line is the main feed. If you have a vacume pump you can unplug the violet from the controler and insert the vavume pump, about 10lbs merc. If it holds the controler more than likley is okay. Then you will want to check the main from under the hood.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Todd84Z
Sep 4, 2015 08:02 AM
BurlyChev
Aug 16, 2015 09:08 PM
mustangman65_79
Aug 11, 2015 03:17 PM
