starter replacement
starter replacement
I have a starter needing replacement on my TA and wondering if there are upgrades available that someone knows about, or just original is sufficient?? Are these difficult do-it-urself projects?? looks like just a few bolts, but any suggestions are appreciated. Thanks again!
1984 Trans Am
5.0 HO with G vin
50K miles automatic
1984 Trans Am
5.0 HO with G vin
50K miles automatic
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: starter replacement
stock is fine unless youre engine is crazy high performance or super high compression
waste of money otherwise
stock starters work plenty fine
good luck
good luck
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
If you have headers or are planning on getting them then put some heat wrap on the starter and soleniod.
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
I just replaced my starter, a couple of bolts huh? LOL! You will have to take your Y-pipe off to get your starter out...what a Pain in the A$$!
mhatfield 14
Oct 24, 2015 07:48 AM
db057
Aug 11, 2015 10:11 PM
