hesitation problem
Old Apr 1, 2007 | 09:42 AM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
hesitation problem
i have a 1982 t/a with a 305 h.o , i have a problem when i go to step pn the gas the car hesitaties and doesnt wanna go then the rpms shoot up and then it fianlly kicks in and goes , is it my plugs or wires , i checked for a vaccum leak but i couldnt find one
Old Apr 1, 2007 | 02:22 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: hesitation problem
Does this happen every time, or just rarely? Just started happening, been doing it for years? Just started as you were taking it out of winter storage and it ran fine last year?
This is the crossfire motor?
Once it gets going, it's good and quick? Or sluggish and feels wrong?
Air filter and fuel filters ok? You check your timing? You make sure all cylinders are getting a spark at all? How do the plugs look? Recent, old? Any plug showing a sign it doesn't match the rest? ie, one is coated in black oil sorta thing?
I'm not familiar with the crossfire setup, so i'm just plugging you with general questions and suggestions. If it's a specific crossfire problem I'm of no help to you.
Old Apr 1, 2007 | 04:17 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i have the same problem in my 1986 tpi fi trans am. v8 5.0 automatic. im stuffing a lot of fresh fuel and cleaning solution through it to see if it can help. jsut came out of winter storage. i have the same issue hesitates and stumbles going slow in 1st gear and reverse but once u speed up past 10pmh rmps shoot up and car kicks into happy land.
Old Apr 1, 2007 | 08:46 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
i pulled it out on friday it ran fine all day friday and saturday, saturday night i drove it and thats when it started happening, i changed the cap and rotor and its a little better now , its got new plugs and wires , and no its not the crossfire motor, my mechanic friend thinks it may be the carb , i got a spare one lying around so im going to put it on and try it. when i brought it out i changed the air filter and filled it up with 91 octane gas.
Old Apr 1, 2007 | 08:54 PM
Sonix's Avatar
Car: 1982 Trans-Am
OK. It's the fuel filter. $2.50. It's the one that looks really small and like a non-metallic tube, they stand out nicely in that aisle. You'll need a 15/16" wrench to get the old one out. Make sure you keep the white plastic seal on the end of the threads or else it'll leak like a sieve.
You had it parked and all the sediment settled in the tank. Then you fired it up and it sucked up all the crap and it went and plugged up the fuel filter.
I'd put money on it being the fuel filter. (ok, not much though )
Don't swap the carb just yet, you might be introducing all new problems if you swap to an unknown carb (ie, not a known good carb).
I'd guess it's just waking up from it's winter slumber sorta problems. Ie, nothing "unadjusted" itself over the winter. Look for the type of things related to sediment build up.
Try fuel filter first. If that doesn't work then maybe check your air valve tension (shot in the dark, but just touch it with your finger to make sure it doesn't flop open)... Then try the other carb.
Old Apr 1, 2007 | 09:49 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
ok thanks for the help, i got the fuel filter i will try it tommorow after work
Old Apr 3, 2007 | 07:27 PM
82_t/a_305's Avatar
Car: 1982 Trans Am
Engine: 305 H.0
Transmission: th350
its still doing it a bit i think just because its a q jet (ive heard their famous for bogging) but it is MUCH better
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
