killed two stock intank pumps
Old Apr 1, 2007 | 02:32 PM
Duke901's Avatar
Car: 89 Formula
i switched over to carb and im still using the stock pump. when i first got the motor running my stock pump died. so then i bought another had it running for like 10 min and it died. the only thing i can think of is that i dont have the return line hooked up. the regulator i bought dont have the return port on it. so do you guys think that with no return line that the pump is getting to hot and it kills it self.
thanks mike
Old Apr 1, 2007 | 03:59 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: killed two stock intank pumps
Oh yah.....that pump will dead head at 80-100 psi. If you've got a regulator on it, sucking it down to 6-8 psi its burning up. You need to have a bypass in your regulator or run a different style pump.
Old Apr 1, 2007 | 04:26 PM
Duke901's Avatar
Car: 89 Formula
so if i get the 3 port regulator it will be fine.
customblackbird
Aug 15, 2021 10:16 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
InfinityShade
Aug 22, 2015 08:00 PM
