gas tank vac ?
Old Apr 3, 2007 | 01:23 AM
mr iroc's Avatar
Car: 88 iroc
Transmission: 5 speed
Axle/Gears: dount know
gas tank vac ?
wen i shut my car off you can hear this sound from the gas cap area wen you turn the gas cap it sound like air is rushing in can any 1 tell me whats wroung?
Old Apr 3, 2007 | 06:24 AM
Re: gas tank vac ?
Nothing.
It's actually pressure. It's supposed to do that. In fact, in alot of places with emisions inspection, one of the things they check for, is that your gas cap holds pressure; your car will fail if it doesn't.
If your car makes a noise like a goose honking or something, maybe a couple or 3 times over a period of several minutes after you shut your car off, and it seems to be coming from the rear of the car, it's the little plastic vent valve in the rear end tunnel just inboard of and to the front of the left rear tire.
pjsparts
Oct 29, 2025 06:39 PM
amcnellis
Sep 16, 2015 04:16 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
rjcme
Sep 5, 2015 01:23 PM
