Comp Springs, Lock and Retainer Help
Old Apr 7, 2007 | 01:31 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I just finished a building and install a new motor and have come to the conclusion that my existing springs wont cut it. Would someone go over my parts order and tell me if they are gonna be correct. The heads are Superflow 190cc Aluminum 64cc chamber, 1.625 Spring Pockets, Bronze guides. More can be found here 190cc Superflowheads
Heres what i have installed so far:
COMP XE282HR .510 .520 230* 230* 236*@.050
Summit Hyd. Roller Lifters
Comp Hi-Tech Pushrods
Summit 1.5 Aluminum RR's
Heres what im needing to order:
Comp 986-16 Springs
Comp 740-16 Retainers
Comp 611-16 10* Valve Locks
The springs are what Comp recommends. Here are the parts# specs:
986-16-
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in): 1.430 in.
Coil Bind Height (in): 1.150 in.
Damper Spring Included: No
Spring Rate (lbs/in): 322 lbs./in.
Inside Diameter of Outer Spring (in): 1.070 in.
Inside Diameter of Inner Spring (in): 0.697 in.
740-16 Retainers
Outside Diameter of Outer Spring (in): 1.500 in.
Retainer Material: Steel
Lock Style: 10 degree
Valve Spring Style: Standard
Retainer Style: Standard
Outside Diameter of Middle Spring (in): 1.060 in.
Inside Diameter of Inner Spring (in): 0.690 in.
611-16 Locks
Valve Stem Diameter: 11/32 in.
Lock Groove Quantity: 1-groove
Lock Material: Hardened steel
Manufacturing Process: Machined
Recessed for Lash Cap: Yes
Sorry for the long post, but i figured the info was needed. Thanks for the help.
Old Apr 7, 2007 | 07:36 PM
Damon's Avatar
Re: Comp Springs, Lock and Retainer Help
I know that those are the correct retainers for the springs. I'll take your word for it on the locks- they look right from the specs.
Don't overlook the installed height of the spring! Different heads the installed height could end up all over the map- shimming may be required. Too tall and you loose pressure. Too short and you could hit coil bind at max lift.
A decent quality valve height mic is expensive- about $80- and worth every penny. Buy it and keep it in your tool kit. If you futz around with engines more than just once in a while you'll be glad you shelled out for one.
Old Apr 8, 2007 | 12:47 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Thanks for the help Damon.
Whats the meaning of "recessed for lash caps"?
I see summit has a height mic for $40. Its from 1.400 to 1.800. I cant find out and dont know what the install height is for these springs. Would it be over 1.800"?
Old Apr 8, 2007 | 07:01 AM
Damon's Avatar
Lash caps are small hardened "buckets" that can be put on the valve tip (upside-down) to prevent the rocker tip from digging/grinding into the valve tip in high-pressure situations. You don't need them, beleive me, and it won't hurt anything by not using them with those locks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
crzycamaro86
Sep 12, 2015 05:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
