Accessory bracket studs ???
Old Apr 8, 2007 | 12:26 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
The studs on the side of the heads, how do you remove them ? What kind of socket, does anyone know ? My backup engine doesn't have them, my old engine has them so yes I need to transfer them.
Old Apr 8, 2007 | 12:44 AM
Gramps's Avatar
Car: 87 Camaro IROC
Re: Accessory bracket studs ???
studs can be removed 2 ways...either use a stud remover or pipe wrench(both will destroy the threads). or you can put 2 nuts on the stud, tighten the 2 nuts up against eachother, then use a wrench to try to remove the stud (2 nuts tightened up against eachother acts as a gripping point so you dont damage the threads)
are they just studs or is there some special head or something
Old Apr 8, 2007 | 09:50 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
All the studs in mine were easily removed with a 12 pt. box wrench. 1/4" I believe.
Old Apr 8, 2007 | 11:52 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
1/4 ?? The studs are that big ?
I'll try the two nuts, and yes the studs have that dumb star head on them. Kinda like an inverted torx bit.
Old Apr 9, 2007 | 07:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Not sure on the 1/4" but a 12 pt box wrench, which EVERYBODY has will work.
Okay. Just went and checked. It's definitely 1/4 inch. It fits like a glove.
Old Apr 9, 2007 | 09:29 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Thanks. Now I'll see if I have one *L* probably misplaced it.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
Derrick86
Oct 1, 2015 05:12 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
