Gasoline, 89 or 91?
Old Apr 11, 2007 | 11:25 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
Gasoline, 89 or 91?
I have a 91 Z28 5.0L TPI and I was wondering which fuel to use, either 89 or 91. My engine as about 130k miles.
Old Apr 11, 2007 | 11:58 AM
danjanIROCZ's Avatar
Car: 1990 IROC-Z
Transmission: 5 Speed
Re: Gasoline, 89 or 91?
If you're stock and haven't advanced the timing at all, regular (87 octane) should work just fine, and I think thats what it was made for from the factory. If you run 87 and it knocks, then youre going to want to run a higher octane.
Old Apr 11, 2007 | 10:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You only need enough octane to prevent detonation under load. The only way to see the knock counts is with a scan tool. If the computer sees too many knocks, it will retard the timing until the knock count drops. This will feel like a lack of performance. Going to a higher octane will feel like more power but all it will be is that the computer isn't retarding the timing.
Using too high of an octane is a waste of money and can actually slow you down because the fuel will be slower to burn.
If the engine doesn't knock with 87, you don't need anything higher. Use a scan tool to find out the knock counts under load.
Old Apr 12, 2007 | 10:20 AM
RebelGQ's Avatar
Car: 91 Camaro Z28
Engine: V8 5.0L
Transmission: auto
I never heard of that before, but thanks for the recommendation
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Justin92GTA
Aug 27, 2015 11:16 PM
carrascoZ28
Jan 9, 2003 11:18 AM
Jer82Z28
Sep 26, 2002 06:14 PM
Sciguyjim
Jul 8, 2002 05:17 PM
