Performance value of cold gasoline??
Old Sep 22, 2002 | 10:28 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
Who here thinks that colder gas injected into the motor would provide more power?
My gas line comes within 1/2" of my header collector, after a run at the track the gas is just starting to boil. so I'm considering so methods to cool my fuel lines down between runs..
I wonder if super cooled gasoline would provide more power though... anyone know?
Old Sep 22, 2002 | 11:52 PM
breathment's Avatar
well usualy gas coolers are only recomended for carbed cars or where vapor lock is a big problem (i think vapor lock is a bigger problem on carbed cars??)
i have too thought about adding a fuel cooler to help cool it down. Try doing a search i know there is some good info out there and some reason that convinced me that i didnt need a fuel cooler, but i don't remember right now. But if ur fuel is boiling then yes i would say u at least need a fuel cooler..
and as far as the performance aspect.. i would think cooler fuel might not give as much a chance to detonation and would keep ur fuel pump living longer..
Old Sep 23, 2002 | 09:19 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
A cheap trick to keeping your gas lines cooler in the engine bay is to wrap them in aluminum foil. This protects them from the heat of the engine and keeps the gas temperature down.
Old Sep 23, 2002 | 10:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Cold gas doesn't atomize well.
Old Sep 23, 2002 | 11:41 PM
Jer82Z28's Avatar
Car: 1987 IROC
Transmission: 7004r
cars seem to run fine in the dead of winter...
I'm thinking colder gas injected into a hot motor would atomize better.. what happens to a gas when it's heated? it expands.. cold gas naturally wanting to expand during the intake charge=better atomization?
Old Sep 24, 2002 | 12:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You said "supercooled", to me that implies a liquid nitrogen bath or something.
I don't think cooling the gas is a way to get any more power. Maybe you're kind of confusing gasoline with the gaseous state of matter. When fuel is injected it's not a gas, it's an aerosol of fine liquid droplets. Cooling a liquid doesn't make it any denser.
Old Sep 26, 2002 | 06:14 PM
Andy Bush's Avatar
I had boiling gasoline after shuting down, because the new headers were too near the new gas line. So I re routed the line because when the gas boiled, it drove the fuel pump backwards like a turbin and filled the tank with hot gasoline.
This might be bs, but as soon as the gasoline is out of a fuel injector nnozzle, you want it to vaporize, so hot gasoline in a high pressure sysem might be better. But you need cold air to get the most power.. So I vote for hot gas and cold air.
But in a carburettor,, the gas is at atmospherric pressure in the float chamber, so if it is hot it might valorize in the jets, and then you'd run lean and might melt the pistons. Just a thought.
Can we get a spell checker going here please??
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
scottmoyer
Sep 7, 2015 07:06 PM
Formula_88AE
Sep 3, 2015 01:47 PM
